What do you guys think about attaching a small fuse block in this location, which is between the glove box and passenger side of the center stack:
My thought is to have the fuse block rest on the metal piece at the bottom and be held in place with Scotch Double Lock velcro to whatever the black component is just above the wires that show in the photo, something like how it is shown just placed loosely in this second photo (so it would be up a bit higher. My only real concern is if I would be adding stress to that black component that it can't handle, but the bulk of any stress should be on the metal panel below - the velcro would just be preventing it from moving side to side. It looks like there is plenty of room to route the wires that would be connected.
Access to the fuse block for changing fuses, in the event of a blown fuse, would be relatively painless and just require a Philips screwdriver for removing the panel to get access. The block would feed a few USB power ports on Gamivitti's replacement speaker panel on the top of the dash, pass along power to some USB power ports I have installed on the rear of the center console, and feed a switched circuit to the rear compartment for power to my mobile router that provides Internet service to my Tesla style head unit. Each circuit on this block can have constant power or switched power. The switched power would be triggered by the cigarette lighter circuit without having to cut or splice any wires thanks to a plug in tap I found on Amazon (I'll be cutting the USB ports off and just using the red wire to provide an accessory trigger to the fuse block):
Amazon product ASIN B07TM4DPQS
Here's the fuse block I'll be using:
www.fuzeblocks.com
Fuzeblocks.com| Compact Switchable Power Distribution with Onboard Relay
The FZ-1 is a uniquely designed compact fuse block. With its onboard relay, you have the choice for each accessory to have constant power or turn on or off automatically with your vehicle. Its 6 individually fused circuits that can be easily configured simply by moving the fuse to a different...
