I am replacing my steel wire rope on my PTO winch with synthetic rope. I need to replace the old steel roller fairlead with an aluminum hawse fairlead and have a question with respect to its best postion.
The PTO winch steel roller fairlead, which has a 2 1/2" slot between the top and bottom roller is centered on the drum. Aluminum hawse fairleads typically have a slot of less than 1". Positioning the new fairlead on the center of the drum would result more downward deflection of the cable through the narrower slot, even on a straight pull, since the wire rope comes off the top of the coil on the PTO winch. (I believe most others come off the bottom).
So I am considering moving the new aluminum fairlead up from center on the drum - so my question is by how much?
