SOLD Portland, OR 1999 LC100
Year
1999
  1. 100 Series
Mileage
161000
Color
GREEN
Outside Link
https://portland.craigslist.org/mlt/cto/d/portland-1999-toyota-land-cruiser/7610092331.html
$22,000
It’s a 1999 ( so came with factory rear locker, that is functional ) Has a pretty extensive Carfax history, and was an Arizona vehicle until about 2017, so there is no rust or corrosion besides a dent in the back above the rear turn signal. Paint could use a refresh though, cuz ya know, its 25 years old.
Currently: 161,000 Miles Everything below was done within the last 6 months / 8000 miles , but I will have to look at documents for exact mileage dates.
2 oil changes ( next one due at 164,000 ) New steering rack / pinion ( done at dealer before I took delivery )
Front, center, and rear diff fluid changed ( 30K intervals )as well as transmission and brake flush ( 60K interval). Timing belt(90K interval), water pump, new radiator ( and associated seals / parts ). 2” ironman lift kit w/ diffdrop and Dobinsons long travel upper control arm
17” Rhino Black Arsenal wheels w/ 285/70-17 Bf Goodrich All terrain Ko2’s and matching spare.
Sony XAV-AX4000 w/ Apple Car Play Everything is functional ( heated seats, windows, electronic rear windows, sunroof , etc ) and no leaks, though the weather stripping in the rear hatch is showing its age, so probably should be refreshed at 1 point.
Paint or clear fading? I’m trying to understand your comment better beyond age. Also, can you attach a photo or two of the dent? PDR or would it be more substantial?
Edit… disregard, I see you have photos in the CL ad. Might be worth adding them here since sometimes ads expire and many folks will likely ask.
It only lets me do 5 photos at a time, but the ad is good for 30 days, but I will keep tabs on it. Thanks for the advice!
It appears to be top layer of paint.
"a dent"
my man, that rear quarter is annihilated. Thats a decent bit of work to bring back to life... unless you pack a tub of bondo in there.
If you considered that "annihliated " then I assume off-roading in the woods isnt your cup of tea.
I hope to god noone bondos it. I am sure any body shop would just pop out the tail light , pop it back, remove the surface rust, paint, and go!
