Polyurethane Bushings
San Antonio, Texas
Just installed Super Pro poly bushings on front and rear sway bars on my 2001 LC 100. Ordered from FIGS Engineering (Mike) at www.ShopFigs.com. Go to www.SuperPro.com.au for item numbers and descriptions.
Front Bushings
LCA Kit - SPF2143K
Rack & Pinion Munt Bushings - SPF2470K
Sway Bar End - SPF2755 SK
Sway Bar Lower - SPF2147K
Sway Bar Mount - SPFSPF1155-K (Measure your sway bar diameter) mine was 26mm
Rear Bushings
Sway Bar End - SPF0280K
Sway Bar Upper Link - SPF0803 4K
Sway Bar Mount - SPF1319-K (Measure your sway bar diameter) mine was 24mm
The sway bar bushings installed with ease and were a great fit. Old bushings were shot. Great product and great service from Figs.
Patrick M.
Hopefully they last a while for you. Mine were toast in 2 years time. Went back to good ol' factory rubbers.
I did the front suspension bushings and used SuperPro. So far so good.
Is that list exhaustive of all the LC bushings? I have a feeling I need to replace the rest..
The above list is what I ordered. There are more items.
I went to www.SuperPro.com.au for their part numbers. When I had the order numbers and measurements, sent a note to "Mike" at www.ShopFigs.com and he sent them out to me.
Ok, I have the part numbers for my original order, I can reference them off of this as a start, appreciate the help.
