Plug on throttle body at manifold connection?
tech_dog
GOLD Star
San Diego
While cleaning and prepping my throttle body I accidentally scraped off what I think was a cork plug intended to close off a port in the manifold. I believe it was the size of the round spot in the picture below. I plan on replacing it with a new dot cut out of gasket material, probably 1/8" thick or so, with a gasket adhesive holding it in place.
Does that sound reasonable? Are there other requirements for this plug?
Thanks,
T.
Yep if we referring to same spot I imagine that was carbon gunk buildup.
That channel was my EGR blockage.
It looks like that top port is intended to be blocked. The gasket has a hole, the manifold has a top port, but it faces into that dirty spot with no where to go.
I found this photo which looks like someone's before image. I wish I'd looked more closely before I scraped mine off, but it looks like nothing but carbon and sludge. I was convinced I scraped off gasket material or something... Thanks for fixing me.
Thanks,
T.
That does not sound reasonable. , there other requirements involved ...
like stopping by your local Toyota Dealer parts dept. and telling your counter-person to put down there personal device and chop-chop because you need :
22271GASKET, THROTTLE BODY
22271-66010
And ........( if you have not replaced it with a OEM TOYOTA Genuine NipponDenso one yet, or in last recent memory ? the below also , it Will come with the 4 needed Copper OEM crush rings ....fyi
23300PFILTER, FUEL(FOR EFI)
23300-69045
23300TGASKET(FOR FUEL FILTER)
90430-12026 Copper OEM crush rings
And the Below KIt of OEM Service Chemicals Too .........
- Please let us know how using the TOYOTA FSM Approach worked for you and why ............?
This is The Way
