do you guys widen or close the spark plug gap relative to "age" of a motor. example; new motor within specs/tolerances use fsm spec gap. Old motor running loose, do you widen or close the spark gap. What typical spark gap do you use?
beaufort-fj60 said:I changed the plugs out yesterday. A few of the cylinders were running hot and a few were oily. The engine has 252,000 miles on it, but runs good enough for daily job site use. Was curious if anyone custom gaps problem cylinders. When and if the motor dies I plan on having it rebuilt, but until then I am going to get every bit of life out of it.
I've heard this several times.dfmorse said:Beaufort;
From a purely theoretical point of view, as the engine ages, going to a larger gap will create a hotter spark; but u can only go so far, because u can create an over voltage problem that reflects back to the stock coil, which can create high voltage windings (secondary coil) arcing and short circuits.
Put a capacitive discharge unit (like Jacobs makes) on an old engine and it will run like new, or better.
beaufort-fj60 said:i gap all of them at 0.031
Tinker said:How can a larger gap make the spark hotter? It makes the spark colder & weaker (less amps).
Fearnofish! said:I gap to .055 and noticed an immediate improvement.
