SD: I've been thinking of reinstalling the first, or even second master, but of the three this one seems to get the best pedal. I had the same symptoms with all three.
I didn't actually replace the master because of the leak on the rear line: I replaced it because a week or so after I fixed the leak, my pedal got mushy and the right rear started locking up. that said, if I don't get it figured out pretty soon, I'm going to switch back to the first, just to ease my mind about that...
Poet: yes, I bled the master; bench bled it, installed, re-bled, attached lines and power bled the whole system including pumping the pedal under vacume, which sort of re-bleeds the master.
Shawn: prop valve aside, that's sort of where I'm stuck. is the rear locking too soon, or is the front not locking soon enough? hopefully will figure it out this morning. ideally I'd have a set of pressure gauges to see exactly what I'm getting to the front and what I'm getting at the rear. unfortunately a set of gauges is proving difficult to find.
Magnum: these are the front monte carlo calipers with no parking brake. there's no adjustment on them. I sort of wish there was: it would make diagnosing this thing a little easier!
OK: after all that, I'm left wondering if I've gotten bad information regarding residual valves. each time I've asked and everything I've read about the residual valves in regard to this 80 series master says that I shouldn't need proportioning valves or residual valves. information regarding if there are actually residual valves built in to the master itself or if they're externally mounted in the 80 itself is lacking.
hmmm... think I'm going residual valve shopping.
thanks for the help guys!
