I'm a fan! Here's my wife's.
And yes.. Those are running boards and 20's. Hey, it's her car until it reaches 100k and she picked out every mod.
stock height?
35's ! I thought they looked big but maybe some sort of an illusion because of the 20 inch wheels . Is the ahc on H in that pic ? If so hows the clearance on N ? Also what kind of mileage is she getting with those ?
I will keep it as simple as possible.
The following members contributed to my lift:
Hoser
Landcruiserphil
Paddo
I have an 05 w/ AHC
I did a modified "hoser" lift in which I moved the AHC height sensors to there highest position. On the front I shortened the heim joint bolt as much as possible without cutting the bolt. On the rear I did Not fabicate a bracket.
What this does is it gives you an approximate 2 inch lift in "N" mode. While leveling out your stance (no rake - which I am a huge fan but some rake is necessary .5-1 inch ideal).
To compensate for the increased pressure on my suspension globes I added Slee's 30mm rear coil spring spacers as "Landcruiserphil" had recommended.
Then comes the tricky part of dialing it all in and this is where you really want to seek out "paddo" for his wealth of knowledge (he's the man.) as recommended I cranked my front torsion bars to get it back into factory pressure specs utilizing Techstream software.
So what I have is a 2 inch lift in N mode with the truck in factory specs with a factory comfort ride.
I also installed a Slee AHC override switch so that I can lock it in H mode for those 5x year when it actually leaves the pavement !! When I switch to "H" I obtain an additional 1" of lift but the ride becomes noticeably stiffer.
There are a few more things I did in the signature line but for now we should be good.
There is a lot more to it and as Sonk76 said to me "an AHC lift is not exactly bkack and white"
Got ya . Pretty much what I'm planning to do also but I just don't want truck to sit stinkbug. Bleeding and replacing the Ahc fluid was top priority as soon as I got it . Also prior to putting on the Arb I moved my front sensors approximately.125 and it yielded approximately.250 of lift to the front . Just testing the waters here . In the near future I plan on installing winch . At that time I will adjust fronts again to sit near level . Still need to purchase the techstream software and adjust tb's accordingly . Will do rear spacers too if need be .
Sweet pics!
Sounds like your on the right path. When adding a winch and adjusting the tb's you may find the ride quality to suffer (may need to swap over to non AHC torsion bars but I would consult others with more experience on that)
If doing a rear bumper / swing out skip the spacers and go with 80 series rear springs. If staying with the stock bumper i would go with new AHC springs plus spacers (I should have)
Just my 2 cents.
I dug up a few crappy pics to reference no lift vs level lift vs slight rake. I will pm you as to not crowd your thread.
