Hello want to install a power inverter; any recommendations on location that others have used?? thinking of this location; also what model have others used/ pro and cons appreciated.
If you mean installing in the cup holder location there is only about 1.5 inches of depth there unless you want to cut into the console storage area.
I know the space above the transmission and right below the shifter get pretty hot as is. Not sure about that center console area. I'd explore the idea of putting the inverter behind the PS, rear panel, opposite of the subwoofer. Then run 120V chords to where you need it.
it would be a very small one to heat up coffee or a small snack etc. thanks
Actually the whole back side of the console removes and has a huge cavity in there at least 14"W x 16"D x 4"H, it looks like that is where the factory Navi goes.
I see it is a two piece console, but how did you get the back of the center console off? I removed the 5 screws on each side...that required some gymnastics, but what next? Does it slide or tilt or what?
thanks, rScotty
