You misunderstood.jwest said:He'd like to do away with the hitch.
Class III receivers for the 60 are rated at 3500 lbs. gross, and that's pulling directly back. Other class III's max out at 5K lbs. They may be able to do better, but that's the rating.
Tow hooks, on the other hand, are rated at 10,000 max.
It's always a potentially lethal situation to yank a vehicle out of trouble. An upturned hook may, in some cases, be more of a liability if the vehicle pulling you out is in a higher elevation than you. This might place more pressure on the upturned weaker portion of the hook itself, whereas a downturned hook in a similar situation will keep the pressure on the strongest, thickest portion of the hook.
OEM hooks are upturned on the front and downturned on the back on the 60's.
That said, it's always a good idea to parachute the cable or strap with a thick blanket, as well as covering both vehicles, whenever possible. But who always does this?
With my luck I would catch the downturned hooks on a branch and get fully stuck..
