Not sure if this can be done. I have 2 piaa lights on my bumper and 4 piaa lights on my roof rack. I would like to replace each existing piaa switch with a 3-way illuminated rocker switch. Currently the piaa lights are hooked up the the parking light circuit.
I would like to have two 12v sources going to each switch, one from the parking light circuit and one from the hi beam circuit.
This is what I would like to happen.
If the switch is push on top, the top led switch light comes on and voltage is supplied from the parking light circuit (parking lights on) to the piaa relay turning on the piaa lights
If the switch is push on the bottom, bottom led comes on and voltage is supplied from the hi beam circuit to the piaa relay, where the piaa lights will only come on with the hi beams.
If the switch is in the center, no voltage going to the piaa relay
I've been playing around with the switch, a battery and meter trying to figure out how to hook it up and no luck. I know enough about electronic to be dangerous; next to nil.
Anyone know how to hook up the switch?
Back of switch
_______
| 1 4 |
| 2 5 |
| 3 6 |
_______
This is the switches I bought.
New Seasense Marine Boat 3-Way On-Off-On Illuminated Rocker Switch 50031262 12V (737765312627) | eBay
ILL. ON/OFF/ON SWITCH - seasense
Thanks,
Dave
Back of switch
_______
| 1 4 |
| 2 5 |
| 3 6 |
_______
Thanks,
Dave
