As much as I like the "calixto is a spammer" thread...actually pretty surprised how long that one has become, I thought I would start a new one.
Looking for some suggestions on doing a head gasket job. The job is way beyond my technical abilities to do myself. Just looking for some advice on what to do, head gasket job, engine swap, crate v8...I don't really have the money right now to do an engine swap considering all the other things that would be needed to be done as well. SD Trux gave me a rough quote of $1500-2k for the job if it doesn't have a cracked head.
So my truck is a 73 F engine with supposedly 102k original miles. Engine seems to be in pretty good overall shape minus the head gasket issue. Was running good before this and would maintain freeway speeds no problem.
Here is my description from the other "spammer" thread:
"Sweet! Bigger problem is that my head gasket is toast. Had crazy heat spikes the last couple days, radiator boiled and spewed fluid I put in when trying to burp. I have a new Thermostat. Took it to a radiator shop and they confirmed the head gasket is done. Fxxx! I've kind of been denying that this might happen soon....I've seen a few signs. Guess I'm gonna see what SDTrux would charge to fix? "
"A little bit of white smoke, coolant around the head where the gasket is(been like this for a couple months) and weird high heat fluctuations. Heat spiking got really bad the last couple days so much that I didn't really want to drive the truck more than a couple miles to surf and back. I was getting up to 210+ and the engine hardly ever gets that hot. Tried to add some fluid yesterday and it took a bunch. Ran it to burp, fluid started coming back out of the filler, it hit 190 pretty quick and boiled over...big mess. Radiator shop ran a block test on it and confirmed. I replaced my thermostat a couple months ago with an aftermarket and was hoping that it had gone bad. I will double check this just to be sure. NS what to do? Engine swap, just a head gasket job or whole top end re-build? ProTrux gave me a ball park quote of 1500-2k! They said that is very rough without being able to look at the vehicle and it's age."
"Yeah, would really like to avoid a swap if possible....lot of time and money for something that is going to be old and used as well. Even going to a 2f or best case senario a new crate v8 is going to be out of my budget range considering all the other things that would need to be done to get it to work....but then again 2k is a lot of money to spend on an old engine. Gonna give it a couple days to weigh all my options and try to figure out what to do."
