Recently replaced the PCV/Grommet and i noticed a silver film (Silver Anti Seize) between the valve cover and the PCV grommet. I didnt have any handy so i went with out it. Seems like a good idea to keep the rubber from sticking. Any thoughts?
I doubt that it was anti-seez on the PCV grommet. If it is a 3FE they have a painted silver VC and the effects of heat, vibration and lube oil is to chafe away at the VC, transferring powdered paint & metal to the grommet.
Also, there's no need for anti-seez or silglyde on that particular grommet, as it is always oily anyway.
As mentioned above, I do recommend antiseez on every metal to metal threaded fastener on a cruiser,
and sil-glyde on every rubber coolant hose.
As mentioned above, I do recommend antiseez on every metal to metal threaded fastener on a cruiser, and sil-glyde on every rubber coolant hose.
