Parting out 95 FZJ80 Engine/Transmission
Austin, Tx
Hi Everyone,
I'm parting out my engine and transmission. They have 170k on them. For those that don't know, the PHH blew out and the engine over heated and is not good. There's a lot of good parts. Plugs, wires, D-cap, rotor have about 20k on them. Tranny is solid. Starter is about 10 months old.
***** Make offer on what you want. If you need it shipped, include the cost of the ride. *****
Thank you for shopping Jeff's Land Cruiser Parts Emporium. :)
All I have left is:
MAF
Alternator
Starter
Transmission
Tcase
Fuel pump - year old OEM
Sold! I'll send you the money when I get home.
Sorry, I did not catch you wanted to the starter too. The starter will be another $80, so $135. The starter cost me more for what your getting everything for. No extra for the shipping, I'll eat that for not reading correctly. :) I'll also include my phone number so you can use the warranty at Advanced Auto Parts.
I need the control assembly that is bolted to the bottom of the upper intake manifold. That would be the wiring, mounts, valves and hoses.
If it's easier to just sent the upper unit complete that would be fine.
Thanks
edit: I'll also take the crank sensor and the protective plate for it that bolts to the upper oil pan.
Thanks
Got a pic of the assembly? Also, you need to make an offer on the parts.
the first three pics are the plug were the assembly plugs into the engine harness and then two shots of the stuff that goes with it. Everything is mounted on two brackets and I'd like it all.
Hey Rick,
Here is pic you requested. Please let me know if there is anything missing.
Regards,
Jeff
I'm interested in:
Oil level sensor
Power steering hose (high pressure)
(Ship to 29621)
on the engine I have there was two of the metal brackets for the parts on the left. I don't have a better picture of it.
the stuff on the right is great.
Hi Rick,
One bracket is in the picture. The other metal bracket will not come out unless I take off the intake manifold. I can do that after I pull the engine. But that will be sometime next month. If you want I can refund some money until then. Please let me know how you would like to proceed.
Regards,
Jeff
Hi Rick,
Regards,
Jeff
I can wait, thanks. What happened is that I helped a friend install a 1993 engine into his 96 and needed these parts to convert the 93 over and took them off of another engine.
Pulling the upper half of the intake will get them out as that is what I did. Two nuts and a few bolts and it lifts right off.
Thanks for the help with this.
Rick
Rick
Cool. I'll get this out to you tomorrow.
I'm interested in:
Oil level sensor
(Ship to 29621)
I'm going to keep the power steering hose because I need it as a sample to get my custom hoses created. If you want, we can do the sensor now, then after I get my hoses built, we can to the host. If you ok with that, please make an offer on the sensor.
Is the EGR valve still good?
I do not know. How can I tell?
Is the diaphram busted you can use a vaccume pump to see if its opening and closing. Is it clogged with carbon? Thanks
Hi Everyone,
I will be in India for 2 week starting today because of work. Please post up what you want and when I get back, I can pull your part(s).
Also, when I get back, I will be pulling the engine/tranny/tcase. So if you want the whole thing, I'll make ya a deal!!!
