- Thread starter
- #61
How much for the coil ignitor? I want to keep my build as OEM as possible
Grey passenger dash grab bar?
Yes my friend, just not in our bass ackwards country.
Drivers window regulator and motor?
I'll have to check on that one. Should be able to let you know tomorrow evening.
Hello
got a few pieces I need, being a 92, you may not have the first two if you don't have rear disc or lockers but I gotta ask.
Right Rear brake caliper mounting plate, 2 bolts from caliper to mounting plate, then 4 bolts hold the plate to the end of the axle. It's also riveted to the backing plate for the drum E-brake setup. Basically everything behind the hub.
4x4 controller in front passenger kick panel. But No lockers, No 4x4 controller.
If the other guy didn't buy your lower tail gate, I want it.
Driver's door master window switch.
I just moved from KC to Denver but I could have my sister grab them or something. She's in Shawnee, where are you in KCK?
Thanks,
Nick
Radiator still available?
