parting out 1970 fj55
orangefj45
Supporting Vendor
norcal
all stock and original. rust in the roof and front fenders. engine has bad rod knock. F-3spd-stock tcase.
so far, these items are spoken for:
rear springs
hood
driver front fender
windshield
i will be taking this to the scrap yard in a week so lemme know asap.
located in stockton CA.i'll be happy to ship the smaller items and mudship larger items. i will be at SNT and can bring parts with me.
To bad i cant find a way to get this pig home georg, you can PM me prices or just post up here, doesn't matter
Stuff i need..
Doors if they arnt in bad shape
Uper tailgate rubber (if its any good)
Tail light lenses
Rear drive shaft
E-brake parts (internals)
Window Cranks (4)
Dome light parts (including the mounting bracket welded to the roof)
Windshield (if it falls through)
If i have enough money lol :p
Rear heater
Heater motor
Fan controls
Front fender emblems
Tailgate
thanks
I'd like the roof braces, if you can cut them out.
Rear view mirror and mount.
Glove box door handle if it's still there.
I have someone in stockton that may be able to pick them up for me.
PM me, let me know if you're interested, thanks!
Stuff i need..
Tail light lenses
Rear drive shaft
Window Cranks (4)
Rear heater
Heater motor
Fan controls
Tailgate
thanks
doors are good, tail gate is decent, i'll pm you and will pull this stuff tomorrow. ;)
i'll make sure all that stuff is in good shape and will get back to you tomorrow.
How much for the Master Clutch Cylinder if it still works, AND the FJ55 shares the same MC as the FJ40?
lunyou
c;utch master works fine, same as a 40 iirc. i'll check sor's site to confirm. $25 shipped
Pm sent :popcorn:
What's the word?
rearview mirror and mount are good
glove box door is junk
i'll cut the roof braces out today
will do my best to get back to you about them tonite. sorry i did'nt reply sooner, once again, too much on my plate.......
georg
we're picking the last few parts off the carcass today; going to the scrap yard tomorrow.:p
No worries, I'm not in a hurry.
If you can cut the braces so there is enough left to weld them back in, that would be helpful.
If Ribz' offer fell through, I can also use the dome light and bracket attached to the forward brace.
Other items I could use:
Gas cap
Fuel door
If the fuel door locks, I could use the tab that is attached to the body that the lock locks to.
Did you get rid of the doors already? I'm interested in the internals if you still have them. Same for the door hinges.
Posted on the other thread, OEM STRAIGHT front bumper?
what the rear passanger quarter panel like ? from the rear door all the way around to the back corner ?
sorry rob, we had already cut them out for a local cruiser-buddy. this piggie learned how to fly! :grinpimp:
got it set aside for you charles. it's not perfect but it's better than most by a long shot. pick it up next time you're on the way thru town.:)
Gas cap
Fuel door
well, not much luck for you. i do have the overflow bottle and the windshield washer bottles and they're in good shape, but the washer motor does'nt seem to work and the rad overflow bottle does'nt look to be the original. it is japanese but was attached with a home made bracket. not sure what it came off of.
the fuel door is junk, no lock either. gas cap was missing. doors are sold. the overhead light was missing and the bracketry damaged, so not worth pulling. roof braces did'nt look good due to rust so i did'nt want to spend the time to cut them out.
so all i have for you are a couple of plastic reservoirs........i'll try to post a pic of them in a little while.
Sounds good!! Thanks!!
71 Fj carb and 4x4 linkage
looking for asian carb for f engine, also need 3 speed xfer case manual controls,shifters and linkage. 2wd 4wd hi and lo.Thanks
