Just got in a 78 FJ40 rusty tub, missing jumpseats and instrument cluster. All else seems to be there, it's unmolested under the hood, everything is there including the smog pump and smog components. I'll list the things I can think of, if there's anything else you are specifically interested in let me know. This thing hasn't run in awhile- and I haven't even tried to get it running. Owner drove it down here from Alaska fourteen years ago and when it got rusty just parked it. He told me it was running fine when parked.
Warn hubs- complete pair $75 4.10 fine spline thirds $125 each Birfs $40 each
Driveshaft either front or rear $45 each Transmission and transfer case with all linkage $225
Cylinder head $125 Short block with crank, pistons, covers, and oil pan $125
Electronic (pointless) ditributor with coil/ignitor $100 Intake and exhaust manifold $50
Starter $15 Alternator with mounting bracket and adjuster $30 Inside rear view mirror $20
Windshield washer reservoir and rad overflow assembly $45 Underhood heater box good resistor $45
Smog pump and all smog gear $95 Air cleaner $30 Underdash ehater box nice shape $50
Bucket seats pair $125 Console $10 Steering wheel $50 Steering column no wheel $45
Lock set (both front doors, ignition, and fuel filler door) $75 Glovebox door nice $24
Ash tray complete assembly $16 Rear heater with lines that come from firewall $75
White wagon wheels not bad shape $40 set Hood nice shape $45 Bezel $24 Aprons $10 each
Roof with sides nice shape very little rust all glass good Headliner not bad either $250
All four doors with all hardware except front door locks (front door panels not included) $125 the set
Steering knuckles with all parts (calipers and rotors included if you want 'em) $45 each
Fuel tank cover $25 Transmission hump uncut $25 Sun visors nice shape $40 the pair
Fuel filler tube, brackets, cover, plastic breather tank and hardware $35 Front full width rubber mat $24
Best way to make contact is to email me at shmukter@pa.metrocast. I've been working all the time lately and am just now starting to get caught up. Bigger items (engine block, doors, roof) pickup only in northeast PA. Will ship the smaller items at buyer's expense. Thanks, Shmukster
