yodafrick
Cruiserhead
Fuel filler door? Boot and trim around shifters?
For the record if any of the dash pads fall thru, I would like to be put on the waiting list as long as they aren't cracked.
Do you have any door trim cups for a 4Runner in gray? I have an sr5.
Pass on door. Actually lookin for trim around shift levers (plastic) that attaches to center console
Do you have the interior plastic part that goes around the stick shifts?
How much for a rear driveshaft? All i need is the t-case end if you could cut it off and put it in a flat rate box that would be awesome
respond with a pm please i may forget to check this
Most everything is gone. If it isn't listed, chances are I don't have it. PM me.
Dash parts 5-15 each, package deal available - I've got enough to do two trucks probably
Rear driveshaft 30
Hood rusty underneath, doesn't show 10
OEM map light 10
Sunvisors pair 15
A/C was converted to 134A and worked fine, now in dry storage. Compressor would make good OBA. $50
NO power steering box, SR5 gauges, inclinometer, tires/wheels, trans/'case, grille, seats, you get the point ...
I know is very old post but I'm looking for the power window switch (driver side ) let me know if u have one. ThanksMost everything is gone. If it isn't listed, chances are I don't have it. PM me.
Rear driveshaft 30
OEM map light 10
Sunvisors pair 15
