Parting 5 fj40's
i have a hard top that needs some help broken half round window you are in seattle the hard top is in redmond got any thing you would like to trade
give me a call chris 206 571 9233
passenger seat mounting bracket
Hi Crockett,
Do you have the passenger seat mounting brackets that will fit a '78. I think they're the same after '73. I need the part that curves around the gas tank and mounts to the floor.
Where are you located?
Hi Dave,
I emailed you, too. I need the section of wiring harness for a 78 FJ40 that plugs in to the empty socket in the pic.
TIA
Oh. Sorry. It's on the PS firewall. Goes to the rear of the vehicle along the PS frame rail. Actually, I might not need that small one. Can you see if you have the section that is the fuel sender wiring? It should plug into the rear harness to a socket with a yellow/red & white/black pair of wires, upper left in the picture.
So what I need is fuel sender pigtail and possibly the rear harness if it's in good condition.
TIA
You know what elseI need is the hard fuel lines that go along the PS frame rail. Near #19 in the lower left of the pic.
And is there a little bracket on the battery tray mounting bracket that the fuel filter bolts to?
Crockett, Just got a 74' 40. Missing wiper on driver side, left tail light/brake light assembly, would like to replace front tail lights with late 70's design, may need to replace brake and master cylinder (would probably take and have for spare if available, both LC emblems on side of front fenders, pair of bumperetts, choke cable, accelerator pedal and linkage. I'm sure there is more, but haven't had enough time to find all things yet.
