Part # for the PWR/2ND switch?
Boulder CO
The pwr/2nd switch on my '05 is getting stuck. Maybe I can clean it but if a new switch isn't pricey I'd just replace. But searching on an OEM parts site under Electrical->Switches and other areas for a half hour I still couldn't find it. Is there any other categories I should look other than Electrical?
When I replaced the middle console cover (mine was beat up) I took a few minutes to clean those switches - they're good as new now after about 10 minutes' work with some switch cleaner...
Thanks @crimsonaudio I'll try to clean it first. BTW is the shifter/middle console cover held by just a few clips? I'm going to try to pry it open with a small flat screwdriver.
looks like it's 84727-53020
Console cover is 4 clips, one at each corner. Cup holder comes out with it and it's attached to center console via a few philips screws.
If you're just after the one switch than you can pry up the the cover, unplug wires leading to button, press sides of button from the bottom to release clips and push button out from the bottom.
I've done this a couple times recently. I'd recommend unplugging all the switches and pulling entire cover off. Great opportunity to clean all the switches really good and vacuum if needed. I was surprised at how much crap was under three. Not sure if mine had ever been opened by previous owner.
It took me a few minutes - a PO had obviously spilled a soda or something in there years ago. Just used some contact cleaner sprayed in there repeatedly while working the switch over and over and now it's literally like new.
Thanks all the suggestions. I removed the cover today, boy! I even found two coins there, gone is the weird rattling sound!
Cleaned the PWR/2ND buttons/switch and they seemed to work well again. The 2ND button was a bit different from the PWR: PWR would stay depressed/down until pressed again, but 2ND would just pop up by itself yet the 2ND light would stay on until the button is pressed again. Also I noticed that PWD and 2ND would not stay on together, only one on at a time. Is that how it is supposed to work?
