Wanted (PA) h55f parts -- spacer and plug, spring and ball
williamsport pa
i'm looking for a couiple of tranny parts -- specifically, the screw plug, spring and locking ball for the 5th shift fork shaft. the plug screws in to the main case near the 5th shift arm but on the side. it is smaller in diameter than the plugs in the transfer case. also need the "spacer" for the output shaft that sits between the 5th gear and the output shaft rear bearing.
thanks
another bump w diagram. used tranny missing spacer and locking ball.............if i can get the spacer i can start to reassemble transfer case
