2006 Cruiser 187000 miles. Had timing chain done about 3000 miles ago. Now throwing these codes. Seems to be running fine. Any thoughts?
Guys, Code came back again. Dealership says its Oil Control Valve on left bank. Wants $500 to replace. Questions
1) Is $500 a good price
2) If I drive it without repair what is the chance of engine damage
3) How easy is it to do this job myself
All replies and advice appreciated
Your problem was unrelated to @Cantatan problem. P0020 directly indicates OCV malfunction. In contrast, P0021 indicates a mechanical problem, specifically the bank 2 cam has over-advanced timing. P0021 Code w/ Check Engine Light Cantatan also has P0018, which indicates the cam timing on bank 2 is not in the same timing as the crankshaft.look at this one to see pics of the valve. At least check the connectors on both sides. I had a different code. p0020
3k miles is perfect timing to fray the crank /cam sensor wires after a belt change.
Anyone delt with p0020 before? VVTi
Just came up on a long drive. Frayed wires or an oil control valve? I'm away from my fsm.forum.ih8mud.com
the valves are about 50 USD
Anytime.Thanks for letting me know your thoughts though
You can pull the PS cover by removing a few bolts and nut off the cover. The DS cover is similar but you also have to remove the camshaft position sensor. Then turn the crank pulley clockwise 1-2 full revolutions until the mark on the crank pulley is lined up with “0” on the timing cover at the crank. Then check that the camshaft pulleys are lined up with the marks on the backing plates. You cannot adjust timing without pulling the timing belt tensioner and timing belt off.Anyone have a write up on how to pull the upper timing covers and check the timing? If the timing is off Can I adjust it without having to do a complete timing belt re-install?
Thanks for all the help
22mm socket and 1/2” ratchet or breaker bar on the pulley bolt. ONLY TURN CLOCKWISE. Also, read the timing belt section of the FSM - it addresses most of your uncertainties.Awesome thanks. Possibly a dumb question but how do i turn the crank pulley?
FYI - https://lc100e.github.io/manual/Thanks, just downloaded that from TIS so shoudl be good to go
