Oxygen Sensor Recommendation
Denso off Amazon - same manufacture as OEM parts. Also make sure to get the special wrench too! Figured out I needed it while down there.
Always Denso with a Toyota. I don't know the model number, but search for it and then search for the best price :)
I think OE Oxygen sensor is supplied by NTK, correct me if I am wrong.
Check out RobRed's TLCFAQ.com. He has all the info you need on O2 sensors.
It doesn't go bad easily. You will know when it is bad, it will throw an engine light at you!:confused:
Last week I checked with the garage. The OBD scanner shown there are total 4 o2 sensor has warning message, but the panel do not have any warning message light! What should I do now? Do I check the O2 sensor 1-by-1 using voltage meter? I found some youtube clip was showing how to check o2 sensor! or reset it by the OBD scanner? I worried it waste the fuel!
I bet the bulb in your warming light is burnt out.
