Overdrive light blinking code 61
Trinidad and Tobago
Hey yall. I keep gettint OD light blinking and the code is 61, VSS #2. I replaced it with a new one, drove a day without light blinking and now it's back on.
Any idea why this may be? Vehicle drives basically normal, goes through all gears smooth, and gears down if I press the OD switch. However I noticed with the OD switch on, if I let off the pedal while on 3rd or 4th, and touch back the pedal, it just goes hard/like a hard thump on the gear as if it's not gearing down and remaining on last gear.
Anything useful in here?
Check the wiring to the sensor too and the connector. Look for damaged wires, bent pins, rusty/dirty connectors etc.
