Out of town and could use some help
100 is leaking coolant in two places close together from say right behind front axle then another spot close to that about inline with front door. Can't tell where it's coming from but doesn't appear to be the radiator or hoses. Any thoughts on what I could check. I doubt winter park colorado has land cruiser mechanics.
Heater tee's between engine and firewall? I don't think I can post a pic yet, but I'm sure someone else will chime in. Lots of helpful folks in Colorado too.
Sounds like it could be the plastic T's top rear of engine. Check the T's and then do a search for correction. You should be able to fix them if you can get the part at the local Toyota store or others have used brass fitting replacements.
Is there more than one of the tees? And are they accessible from the top side or bottom side. I'm not where I can look at it but am in Denver and could get the part.
Dang that is perfect. I need to learn how to search the forums better. I never seem to find what I need with my searches. I am going to for sure get these two tees n denver before we head back to where the 100 is cause that is exactly where the drips are coming from. You guys are all so awesome. Hopefully someday I can post something that will help someone.
While likely the T's did you check the drain spigots in the block? I believe there are least two aside from the one on the radiator
...via IH8MUD app
One on each side, towards the rear of the block. 10mm socket to open or close the spigots...u-joint coupling and extension handy for the one on the passenger side.
thanks again. bought two t's in Denver went back to winterpark and my 18 yr old climbed under the hood and got them switched out and no more leaks. back in Amarillo with no problems currently. 215000 miles and counting
Good to hear!
