Not even sure where to begin with this thread, we picked up this 94 almost a year ago and its been non-stop action in the shop ever since. I wanted to do a thread and keep it up to date through the process but I couldnt find the time and energy to start and maintain anything else.
One of the first projects was resealing the birfields with new wheel bearings, brass bushings in the axle housing, etc, you guys know the drill. I did new brake calipers, rotors and pads at this time. I have since opened them back up and installed a Trail Gear Locking nut upgrade set. The drivers side appears to be transfering grease to the axle housing, but doesnt leak oil. I recently change the front diff oil once again, so I will have to check again and see if theres transfering.
We then installed a OME "J" Spring lift, which without bumpers or any extra weight ended up being about a 5 inch lift, which was stiff at the time but is fine now with an ARB bumper on the truck. 35 inch tires were put on, and the flares were removed around this time also. The ujoints were changed.
Anyway into the big part. One day I decided to take an orbital sander to the truck and that kicked off 6 months of body work, inside and out, to fix all the obvious rust. This involved gutting the interior as the previous owner had destroyed the carpet and let rust grow under it. This included removing the rear heater, welding in a plug on that hole, remove all the old butyl rubber, etc.
There was a good chunck of rust in the lh rear wheel wheel going through the wheel well and all along the bottom of the lh rear corner of the body. There was also a large section of rust on the right hand rear wheel well in front of the tire.
