- Location
- United States
No Affiliation, just ran across these on CL.
This is an 80 with a custom paint job - worth the look.
($($($ 1992 Toyota Landcruiser Custom Paint $)$)$) 196k Miles 3rd Seat
1963 Fj45 Toyota Landcruiser Rock Crawler 6,500
Small block Chevrolet engine (built) automatic, springover, 4-wheel disc brakes, bead locks, alot of work done at a reputable 4x4 shop, unfinished project with not much further to go. Contact Scott at email or call 541-992-2563.
Toyota Landcruiser jdm Turbo diesel - $16500 (Portland 97224)
model: P-HJ61V-PEMZX serial: HJ61-12386 - Extremely rare 4WD, AT, 6 Cyl. w/ factory Toyota 4.0 Turbo Direct Injected diesel (looks like what a A-series Cummins should have). Comes with a factory P.T.O. winch (which is currently fitted w/ an extremely nice cable, nestled behind the extended bumper), factory high roof & power moon-roof, w/ shade. Other Features include: 4 spd Automatic Transmission (industrial grade Hino type), Running Boards, Power Locks, Power Windows, Power Steering, Power Brakes (brakes are in good condition), Full-Floating Heavy Duty rear end (four bearing not two), Power Moon/Roof, Air Conditioning (works flawlessly and yes it blows cold), original Recaro Style seats w/ Lumbar Support (drivers Side), new Costco BF Goodrich T/A's, window guards in rear cargo area. Runs, drives, shifts & stops great and is extremely reliable and easy to start; even below freezing. Gets about 25-30 M.P.G. highway. New Dual 12V Batteries (24 Volt System). Body is clean, straight & rust free with some minor scratches/wear. Interior; drivers seat just starting to show the typical wear on the lower cushion that Toyota's are known for. It has been maintained by a local diesel mechanic. RHD, originally from Japan, STEREO converted to North American type; powered off very efficient 24V/12VDC Solar Converter. Odometer/trip read in miles, MPH/kilometers ON DIAL. MILEAGE approx. 153,000. Currently registered and licensed in Oregon to me. SERIOUS INQUIRIES ONLY PLEASE
Toyota Landcruiser Hj47 1983 - $24500 (Oregon)
In real good shape, right-hand drive (easy to drive), diesel, 4-speed, front disc brakes. Rare and hard to find classic. Right out of an african safari, runs good. Great camping rig. Contact Scott 541-992-2563
Toyota Landcruiser fj45 1966 - $8500 (Oregon)
1966 fj45 Pick up truck with a 2F engine/4 speed transmission. Short bed. Removable hard top. Rare.
All brakes gone through. Runs good. Does have rust issues.
Toyota Landcruiser fj43 1974 - $21500 (Oregon)
TOYOTA LANDCRUISER fj43 1974 21,500
Fj43 factory rag top. Runs good. Brakes good. Drives good. 4-speed. 16-inch tires. 14" longer than an fj40. Nice upholstery. Unique and somewhat rare vehicle. Khaki in color. Contact Scott 541-992-2563
1981 Toyota Landcruiser BJ44 - $15000 (NE Portland)
Where do I start? Well, to be serious I don't really want to sell this so if response is limited I will pull it and store it until I have the time to work on it.
1981 BJ44, 4 cyl diesel, 4 speed, right hand drive, legally imported and registered in Oregon. This rig was purchased at auction in Japan, shipped to Vancouver BC, and then brought down to Oregon via a customs broker in Sumas Washington in the Fall of 2007. Currently the odometer shows 39,090 Km, or approximately 24,289 miles. If you are not familiar with Landcruisers the BJ44 is approximately 18" longer than the prevalent FJ40s that were brought into the states. Toyota never imported the longer wheel base 40 series cruisers, nor did they import any diesel rigs either. I have seen very few of these for sale or on the 4x4 forums so it is a rare find indeed.
Since I have had it I have done the following:
Replaced all fluids
Rebuilt front end
Replaced motor mounts
New custom springs, bushings, and shocks
New wheels and tires - 33x12.5 R15 MT
Rebuild front steering box
Rebuild injectors
Replace fuel lines with SS
Install 60 Amp 24v to 13.8v converter
Roundeye conversion headlamps
New Les Schwab HD batteries
other misc items
All work has been performed by Land Cruiser Northwest
Now for the bad - there is rust that needs to be dealt with. The bottom of the rear doors are the worst in addition to other areas that need attention. I have tried to be as honest as I can with the pictures. For me to keep this rig what I really need is a large garage and time to take it apart to replace or repair the rust - both things I don't currently have.
Here is a link to more detailed photos:
Picasa Web Albums - Mike & Alisa - 1981 BJ44
The bottom line is that this is mechanically a solid cruiser that needs some cosmetic loving. I recently purchased a nice FJ62 which is a great rig, but does not get the same response as driving the 44. I also have a pending basement remodel so unfortunately it is low on the list.
Take a look and then let me know if you interested in seeing it in person.
Replaced all fluids
Rebuilt front end
Rebuild injectors
other misc items
