For Sale ON Canada: 60 series 24v Glow plug Pre-Heat timer
Bowmanville, Ontario
28521-68120 glow plug pre heat timer. I parted out this truck quite some time ago and have some extra electrical related stuff kicking around. It was my daily driver so, everything worked when I pulled it out. $80 USD plus the ride.
Hi there
I dont suppose you still have this 24v glow plug timer do you ? Im in Scotland and have just discovered my one is water damaged......
cheers
Neil Sutherland
Hi there
cheers
Neil Sutherland
I think I may still have that pre-heat timer. Let me have a look and get back to you.
Hi there.
Thanks for the quick reply man
Yes i would. Its to a place called Peebles in Scotland. Postcode is EH45 9HF.
Normal air mail would be fine.
Do you by any chance happen to have the Glow Plug Resistor that was stuck in the intake manifold ?
My 1989 UK spec Hj60 has only one resistor rather than the two of previous years.
Its 28621-68020 GLOW PLUG RESISTOR
If you happened to have the earlier resistor i would be interested in that also as it may still work (mine tested dead)
Any other electrical bits kicking about ? Need an inner H1 square headlight if you happened to have one of those
Parts for HJ60 series cruisers in the UK are very limited.
cheers
Neil Sutherland
