OME lift
CondeCruiser
Conde, Va.
Hey guys. I started this thread to see if anyone would be interested in the 2" OME lift on my red 40. It may have 500 miles on it. Probably less. I will be replacing it with a Pro-Comp lift, since i have changed direction again on my '70. It will include the springs, shocks, shackles and steering stabilizer. Will also offer up my lift to help with installation if that's something someone may want. I can get some pics if there is interest. I will possibly be pulling it this weekend.
Ok, I’ll bite… what’s the new plan for the other one??
Low rider, drag racer, all electric?
All of the above. Im sure you can guess. Its going to be a while.
What is the difference between the kits?
The OME is stiffer. Shackle angle is more vertical. Pro-comp springs are a bit longer and center the axle in the wheel well instead of forward like OME.
You can see what I mean in the pic. The rear axle is pushed forward. It allows articulation so your not hitting the rear corner. Not planning on wheeling this so the centered axle is visually appealing. The blue one has the Pro-Comp springs and way better shackle angle
Here are 2 more pics from Redlinelandcruisers.com
