Olds Alero
Status
Not open for further replies.
Pequot Lakes MN
Any one ever done a brake job on one.... going to help out a friend and fix her brakes... Do the calipers just push in like most older cars or do they screw in like some of the newer stuff I have seen.... If so do I need a special tool....
The fronts never screw in. The rears might. If the parking brake is in the caliper they screw in. If it has a separate p-brake, then it has a regular caliper,if it has discs on the rear at all.
I see that Aleros came with either drums or discs on the rear and that they do have a listing for parking brake shoes, which suggests a separate p-brake system.
You can turn in the parking brake type calipers in with a pair of channel locks and a c-clamp, but it's a PIA and very easy to rip the dust boot. It's better to buy the tool. It's cheap and easily available from the place you buy the parts from.
Thanks so much!!!!!!!!!!!!!!! Drums in the back of this one... and they dont need work... so just the fronts.....
Thanks again!!!!!!!!!!!!!
Status
