- Location
- Ojai, California 93023 United States
Running, Driving* Project 1989 MK1B MR2
$2000 OBO
I have had this since late 2011 and slowly fixed it up while commuting with it until I slid it into a utility pole last October. I have too many projects right now so I am looking for a good home and MR2 enthusiast to send this to.
Passenger side shock tower is crumpled and the A-Pillar is pushed up such that the door glass doesn't line up.
It fire right up and runs smooth. *It steers and can be driven short distances, but will need to be trailered.
If you are a sheetmetal and body whiz, this project is for you!
If you have a shell in need of a complete drivetrain and interior swap, you have come to the right place!
If you want to chop off the front and build a tube frame for a race car, right on!
I am not parting this out or selling it to someone who has that intention.
Clean title (I did not and do not have collision, so the insurance never looked at it)
280,600 miles
Most recent dyno (11-8-2021)
99.5 Bhp
92.8 lb-ft torque
280,000 mile service included:
-New Timing belt
-New Accessory belts
-New water pump
-Cleaned fuel injectors (Mr Injector)
-Valve clearances checked (all within specification)
-Oil Change
-Coolant change
-Spark Plugs, wires, cap and rotor
Oil changed every 3,333 miles with Castrol GTX 10W30
6 Speed Transmission filled with mix of Redline MTL and MT-90
Toyota Red Long Life coolant
Used JDM Long block installed early 2012 at 159,343 miles
Exedy 11 lb chromoly lightweight flywheel (stock was 17 lbs)
Woodsport 6 Speed conversion installed at ~180,000 miles
Polyurethane suspension bushings
Custom Center console
Custom Door cards
TwosRUs shift linkage bearings
Dashmat over black dash with almost no cracks.
Tokico Shocks
Dynamat sound deadening
Quiet custom 2" exhaust with multiple resonators
TVIS Delete (extra parts include 2 extra TVIS plates, one of which holds vacuum)
installed November 2022
Tercel steering wheel
Gas strut hood prop
Factory Jack
Cover King car cover (car has been covered since accident)
Paint and bodywork done in 2018/2019
Toyota Super White 040 single stage paint
No rot, only surface rust on the windshield frame and the spare tire pan.
Tons of extra parts and FSM (see pics in followup posts)
DOES NOT INCLUDE:
Enkei Alloy Wheels
2 Ball Shift Knob
Odyssey ODP-AGM35 Battery
$2000 OBO
280,600 miles
99.5 Bhp
92.8 lb-ft torque
-New Timing belt
-New water pump
-Oil Change
-Coolant change
Custom Door cards
Tokico Shocks
Gas strut hood prop
Factory Jack
DOES NOT INCLUDE:
Enkei Alloy Wheels
2 Ball Shift Knob
