Oil Pump Cover Seal.....DONE
Blackdog
"Y'all smell that?"
Next to the particle accelerator
You guessed it. I spent the day Saturday getting intimate knowledge of the front of my motor. Changed the oil pump cover seal and front main seal. The OPCS was so much fun that I put it back together and took it apart again just to see how long it would take. Well, realy I did it twice because I misaligned the O-ring seal the first time and didn't realize it until I was putting the steering stabilizer back on.......:whoops::censor:
If I had to do it over again, I would not hesitate to break into it again. All went smoothly except for the previously mentioned SNAFU. I was really hesitant to do this job because of some of the horror stories I read on the forum, but as easy as it turned out to be, I would hate to have paid anybody else to do it for me. I am fairly certain the president of DLC paid tooooo much to have this job done at a shop (even if it was the least expensive quote he got on it):p
All told, this job could be done in less than three hours and for roughly $35 in parts and a few bucks for incidentals like locktite, shop towels, and any misc. tools you don't already own (30mm socket and breaker bar). The STICKY thread in the FAQ section is a pricelesss assett for this project. If you are leaking oil from the front of your motor, DIVE IN.
:banana::banana: job
I've started this job twice and only have broken tools for my efforts. Bent a solid 1/2" drive bar with starter bump method. By hand I have cracked a 1/2" drive breaker bar (had a 3' pipe on it) and at the same time cracked a 14 mm deep socket on a flex plate bolt. I'm either going to live with the leak or go larger on the tools.
Stories like Godwin's are the reason I was so hesitant to do this job. I guess I was very fortunate that all went smooth.
Stories like mine are the reason I'm hesitant to try it again:D And when the 14 mm socket cracked it also flew up into the cavity with the flexplate, but was easy enough to pull out. Next time, if I decide to give this another shot, I'm pulling the radiator so that I can hit the crank nut with an impact wrench.
The PHH is the other one I've been putting off.
The PHH is really easy (in the drive way) if you break the bottom tab on metal tube going to the top of the engine..
I would hate to have to do it on the side of the road or a trail in the dark though..
