Oil Change Intervals
umpqua
GOLD Star
Portland, OR
Please excuse if this has been asked. New to the board.
I've got two cruisers (fj40-62). Both of these are being driven way less than 3K in three months time. I've always followed the 3K or 3 month oil change routine.
How important is it to change the oil after 3 months if you are putting less than 1500 miles on the oil?
Also, the 1980 40 had the catalytic converter removed years ago. Not a problem in the south, but recently moved to the Pacific NW. It won't pass deq so I continue to have it liscensed in the previous state. Would like to have local plates if possible but would have to put a converter back on. What kind (if any) performance loss should I expect by doing so?
Thanks.
I should know the anwser as I have 9 cruisers I drive on and off, none get alot of miles.........but I don't........... so I just change the oil when it feels right....normaly I will have "oil change day" at my place and do 4-5 of them. I think you oil is fine for up to a year these days.
on the cat, I had my 82 fj40 cat replaced(I didn't have to as non test area) I had Walts do it, was $300 for a direct fit, not a butcher job of hackin up the stock stuff and welding what ever they had in, this was made to fit and only cost $50 more. Power........I don't think you will notice any decrese.
where are you in WA? I am down in Gig Harbor
Thanks.
They say to change the oil every six months if a vehicle is NOT being used. You're battling the condensation issue.
For my rigs I use Amsoil heavy duty diesel oil. I use Amsoil bypass fitler kits too.
In that senario I run the rigs 10,000+ thousand miles between changes.
I send of oil analysis to make sure everything's ok too.
If you use a bypass filter and a quality synthetic oil you can go a very long time between changes.
TB
But if you didn't use synthetic since day one, you may start to get leaks. Ask me how I know.
Actually, more so on diffs, trans and xfer than motor, but they are there.
Not to turn you away from syn, just letting you know what to expect.
Back to question... I think the length of your average journey is a consideration. I know in my manual it has a schedule for severe operating conditions. They include things like dusty, heavy towing and then the last one.. lots of short journeys. I fall into that last category and change mine every 3 months / 1500 miles. For my schedule, the maunual also says change the filter only every other change - which I follow. Should also mention that mine's a diesel.
Jim
Really appreciate the input.....thanks for the response. From what I've read I think that I may go every 4-5 months. That should get me there on the 62.
I enjoy reading this site. Folks seem to be friendly.
I live in Portland.
