Hi,
I saw Eleblancs thread on oil catch cans and thought I'd post my most recent mod. Put this in a couple of weeks ago.
No issues yet. Haven't blown any seals. Like eleblanc found, I do use a bit of oil after my oil change. My dipstick will show
I use an 8th between the high and low marks. Once this is used (first 100 k's or so I use none/very little (only small blow-by)
until the next service. After adding a turbo boost controller, gauge and uping the boost to 12/13psi I notice the extra use in oil
as above. Before uping the boost no oil was used. Part of my reason for the install was that I didn't want the crankcase venting
directly into the air intake. The oil residue was getting sucked into the turbo and then a small amout was making its way into the
vacuum system via the inlet manifold/crossover pipe. The shut of valve had oil on it and maybe a very faint drip. Now the can is
installed I hope this doesn't happen and when I find the time I'm going to pull the intake and give it a clean. The blow-by is
better in the can than in my engine.
I bought a cheap ricer catch can. I put 5/8" fittings on it so the blow-by flow wasn't restricted. Mounted the can in the engine
bay and connected it up. Used hydrolic hose so there would be no issues with the hose perishing. It worked well I think.
Some pics:
Excuse my filthy engine
Some pics:
