Hey guys,
Just ****ed up, been a long time since I’ve made such a silly mistake.
I’ve been overhauling my 1HDT and I had removed the timing belt (was doing some custom brackets etc so hadn’t put it back on yet). Anyway the weather was nice today and I had some assistance from the misses so I removed the engine from the cruiser (to install new clutch etc).
Anyway in the process of removing the flywheel bolts I managed to spin the motor over without a timing belt installed. I only noticed when the motor suddenly stopped spinning “freely” which I assume is piston making contact with valves. (Edit spun as in by pressure from the socket/ratchet trying to loosen the bolt, NOT using the starter motor).
Now I didn’t put much pressure on so I doubt I’ve done much damage (I’m really hoping not) but what’s the best way to “reset” the timing? Should I remove all the rockers and spin the motor back to the timing mark and start from scratch?
I’m going to pull the injectors and try and put a scope/camera down to inspect the pistons just to be sure
So annoyed at myself. I’m usually very methodical and logical but I was under a bit of time pressure and just didn’t think it through
