SOLD OH. OEM power Steering Pump and bracket like new condition
dlzadl
Akron, OH
OEM power steering pump and bracket. Came off a 1981 Fj60. Brand new was run for less than 1000 miles and the the truck was t boned by an f250. Comes with all shown. $ 500 plus the ride
Hello, Thanks. Can you check to see if your block is drilled for the bracket? This assembly is out of an 11/80 FJ60 with a 2F Should work if your block is drilled. If so we can further check it out
I looked at SOR, they have two different part numbers. But that is not necessarily meaning they are different. If you have the holes we can ask someone who knows
Hello, this is where I think it Mounts, not sure what hole pattern should be, what does yours look like? Thanks
Here you go
Not sure and it has been awhile since I have had my 60. Here is a side view of the bracket. It looks close to 3 inches on center. The bracket may be different but I bet the pump is the same
Thanks Jack. All input is appreciated
Hey KC, I am looking at the SOR drawing and it looks different, not sure we want to screw this up.
@fj40ingkc here is a pic from a 79 which is your same setup.
The part number for the bracket is pretty visible. If you do have an aftermarket ac compressor on the other side you will have to do a little rework to get the pulleys lined up. You will need to remove the idler pulley and do something creative with the compressor and alternator. Ask me how I know. 😁
@JVZii thanks for the pics, I was wondering if my bracket like yours, which ac compressor is attached to was stock, now I realize it is. So the pulleys don’t line up? Did you have to machine the pulley shaft? Have a thread on this? Cheers -max
Also what lines are those running on your cross member infront of the radiator cage?
