features:
36v 190w solar panel w/ Blue Sky MPPT charge controller.
Progressive Dynamics 40 amp power converter for shore power.
Optima Blue Top Marine battery
set up for vehicle/shore/solar power charging
2 - 120v power outlets on separate breakers. One inside for AC or other accessories. One in galley for cooking or etc. Only usable with shore power or genset. No inverter.
New 7000 series Fantastic Vent fan with remote.
12v LED interior lighting
2 - 5v USB charging ports
5000 BTU Air Conditioner (shore power only)
Fully insulated sleeping area
Independent suspension
5x4.5" hubs w/electric trailer brakes (currently has spacer/adapter to the new Cherokee bolt pattern) Easily modified by replacing the hubs to match your bolt pattern.
Aluminium Wheels with automotive tires
Multi-axis hitch rated at 12k lbs. (did I mention this was overbuilt)
approximately 18" of clearance between frame and ground.
Full metal frame under body.
sleeps 2.
entry doors on both sides.
I have lots of build pics.
