- Location
- United States
OEM power steering box rebuilt $950 plus the ride
It can , you would need to shorten the steering shaft 30mm, install a bracket and possibly a pulley for a PS pumpI have a 1972 FJ40 does this box work on mine?
what does this go to?? fj80? is it remanned?View attachment 1600749
Thanks for the update, so a mini truck box with a Dory bracket might be better for a 72 and earlier, and cheaper too. I have a couple of mini truck boxes also9/72 the steering box changed. Prior to that date the column was part of the steering box. Believe the pedestal on the frame changed as well. The entire column including opening in the firewall changed. Easier to install in 73 plus models (9/72). Anything is possible but the 79+ power steering is really the same as the 73+ models except the steering box is longer and shaft in the column is a little shorter.
