OEM Tail light / Lamp Electrical Connector Differences / Types FJ40 1/75 - 10/ 84 ( 8/26/2019 Final OEM TOYOTA Parts Solution Updates )
do u have OEM toyota tail lamps or aftermarket ones ? 4 pin connectors or 6 pin ovals ? photos posted here will be very helpful ..................... lets see if we can help coolman will be around soon , hopefully .......... matt
OEM KUSTOM KIOTo LED KIT JAPAN 4th Generation FJ40 Tail Lamps Lights Vintage Land Cruiser Rear Lights Fits 1973-10/85 40 Series 12v Volts and 24v Volts Combatable - VintageTEqParts.com
OEM KOITO KUSTOM LED KIT JAPAN 4th Generation FJ40 Tail Lamps Vintage Land Cruiser Rear Lights 12v VOLTS and...
vintageteqparts.com
12V And. 24V LED Bulbs Applications Coverage .....FYI
OEM KUSTOM KOITO LED
MADE IN JAPAN
Vintage Land Cruiser Rear Lights KIT
a
" MUST HAVE "
for all the
" MUST HAVES " here on MUD
$394 = KIT
MANY Detailed and notable Modern Factory Design Improvements in both corrosion resistance and electrical conductivity too ..
: Sealed O-Ring Connector Plugs water proof as they get ..
: : Longer Plug Tail Leeds excused in water proof loom
: no more 5mm machine screw B/S mounting lamps to rear frame member section on chassis !
NOW : affixed threaded studs to lamp base housing only need a hex nut , simple 5 STAR approach I will give Toyota here
- Rubber water proof lamp bases boots are tight and snug , top shelf here
- ALL 3 lamp sockets have a independent ground wir
affixed to them with a brass rivet and then coated in green anti rust coating
set / pair / LH and RH lamps sold together .....
thanks for your support !
vintageteqparts.com
