OEM BRAKE CALIPERS
Save those NAPA receipts for the eclipse reman calipers! I believe you get a 2 year warranty and one of my eclipse caliper pistons seized up (probably from mud/sand and not cleaning) so I had both calipers replaced for free. The warranty said you needed to write a detailed description and blah blah blah but the guys at the store just told me to bring them in, just needed the old receipts.
I ordered mine online and just picked them up at the store. If they lost their own receipt, that will be their problem. I printed that sucker off for the thick binder full receipts I have collected since I found the right hole to dump money into. ;)
Most braking system component changes are tradeoffs. There are only a few things that generally result in Pareto-ish improvement that you could look into:
Larger brake booster
Larger rotor diameter
Higher coefficient of friction pads
Whats with your frequent use of caps lock? Its like you're grandma in the 90s trying to internet
I hear all that Im just going go with napa's as far as cap locks sometimes Im a tad busy on the ole internet of things and voice rec goes caps. it happens.
I think that’s how I ordered mine originally as well. I’ve just gotten in the habit of keeping all my receipts in a giant unorganized notebook so I just used a paper copy. They accepted my other caliper that was functioning fine but figured I’d replace both at the same time.
One thing for future readers, check the Napa eclipse caliper holes for correct bolt sizes for OEM size...I’m one of the dumb asses that had to drill out one of the holes to fit a bigger bolt since one of my knuckle stud holes was stripped and retapped. Sorry for whoever gets the Napa remanned caliper with a size 19 (I think???) bolt hole.
Wish I had ordered oem copper washers like beno recommended tho.
