SOLD Ocean Springs 2UZ-FE Engine Wiring Harness out of 2000 100 series TLC
Mississippi Gulf Coast
I'm selling a complete engine harness out of a 2000 Toyota LC. All connectors intact, except as noted below. This is both the starter side harness and the engine side harness and has the connections to the transmission. This harness came out of a running and driving 2000 Toyota Land Cruiser with 200k miles.
$200 plus shipping
These are the knock sensor wires under the manifold (in the valley). the quick disconnect clip broke. I think the heat gets to the connectors under here.
This is the connection to the throttle body. The quick disconnect clip broke. It can be wire tied to the throttle body.
We think this is the water temp sensor. You just need a new connector body here and this should slide into the body.
Here is what is for sale. you can have the starter too if you want it.
