For Sale Oasis HP1000 compressor 12 and 24 Volt
Bay Area, CA
No longer available for sale.
I'm posting this up in this section because this compressor can run on both 12 and 24 volts. At 24v DC performance dramatically increases up to 16 CFM @ 100 psi with a maximum pressure of 125 psi.
Compressor has only seen light usage and has been in storage for the past 5 years. Build date is 3/06. I will also include the braided leader line, coalescing filter, one-way valve and fittings.
Check out these reviews:
Tire Inflator Comparison
Compressor Must Have - Off Road Magazine
_________________________
Oasis HP 1000 Air Compressor
THE HP1000 uses a 4.5", 5 hp motor. Tests at 12v have shown outputs from 14 CFM @ 0 psi to 8 CFM at 100 psi, with a maximum pressure of 200 psi. At 24v DC performance dramatically increases up to 16 CFM @ 100 psi with a maximum pressure of 125 psi. The HPIOOO™ employs a unique high-output design that operates on standard vehicle electrical systems yet consumes no more power than other compressors for the same task.
Size: 17" L x 10" H x 7" W
Weight: 45 lbs
Dimensions ( L x W x H ) 17" x 7" x 10"
Net Weight ( Lbs. ) 45
Shipping Weight ( Lbs. ) 49
Motor Type Series Wound
Motor Thermal Protector Yes
Low Voltage Cutoff Protector Yes
Performance @ 12Vdc
Max Pressure 175
Max Restart Pressure 100
Horsepower 2.5
Current at Max Load (amps) 200
Power at Max Load (watts) 2400 Performance @ 24Vdc
Max Pressure 175
Max Restart Pressure 150
Horsepower 5
Current at Max Load (amps) 220
Power at Max Load (watts) 5280
