O2 Sensor Part 3...
Bay Area
'99 UZJ100 w/ 78000+ miles
Hello forum... this is the 3rd posting re. O2 sensor. Here's the sit: I had the O2 sensors (Bank 2, sensor 1 & 2) replaced by a local independent import/domestic garage. After a day, the "Check Engine Light" came on again. So, I threw in the code reader and got the same P0155 (Bank 2 sensor 1). Did the mechanic miss anything? Should I get it check by Toyota-only tech? Thank you again... : :confused:
I had this problem and it turned out to be an exhaust manifold crack -do a search for cracked exhaust manifold to find posts. Hope that is not your problem. Does the motor make a ticking sound when starting cold that seems to go away after it warms to operatiing temp?
Sometimes this is caused by the mechanic not resetting the computer. It keeps the code in memory until the computer is reset. On a lot of cars you can reset the computer if you just disconnect the negative batt cable for a couple of minutes. Might be something to try before you spend any more money.
