NWMP aux fuel tank install
PNW
I've been lugging around a NWMP fuel tank for the last 14 months and I finally got tired of moving it around to different locations, so I decided to finally install it today. It's supposed to be a gravity feed system with a hose running into a fitting where the main tank drain plug is on the bottom. Problem with this is I don't like the idea of having something hang even lower off the main tank, especially a brass fitting that could drain all my fuel if it gets hit hard enough.
So I thought of putting a shut valve on it (elec or manual) and have the aux tank drain into the filler neck vent tube for the main tank, but the filler neck is too high and I don't want to put a hole lower than that in the side of the main tank because I'm afraid it'll leak.
My final option is an electric fuel pump, but fuel pumps can get damaged when they run dry from heat build up and I would have no way of knowing when to shut off the extra pump. I can't find anything saying they are safe for short periods of dry running and likewise nothing about how they work except that they do not use a diaphragm.
This is what I came up with, though it may be a bit over engineered it should save the pump from running dry, and if the rest of the system wiring fails a jumper wire across the load side of the relay will still turn on the fuel pump
Red: fuel lines
Dk Blue: wiring
Parts: low pressure nitrous fuel safety switch (adjustable 2-5psi), fuel pump, momentary & toggle switches, relay, slight fuel line restriction (small crimp in steel fuel line to main tank)
- the toggle switch turns on the system, but the relay won't turn on the fuel pump until there is ~3psi at the low pressure switch
- press the momentary switch to bypass the pressure switch and turn on the relay and fuel pump
- pressure builds behind the restriction and makes the pressure switch close, the momentary switch can be let go now as the relay will stay on
- when the aux tank runs dry the pressure switch opens deactivating the relay and fuel pump
if I really want to get fancy, I was thinking I could run a wire from the + side of the fuel pump back up to the switch panel through an LED and on to ground as a "fuel pump on" indicator light
Installing the tank is easy, so I'll leave out the bits about drilling holes and bolting it into place. It's the details that'll make it trouble free in the long run . . . like an exhaust heat shield so the gas doesn't start get too hot (excessive vapor/boiling)
view from the wheel well - before I fill it for the first time I'd like to replace the rubber hose with steel braided to help deter thieves from thinking it would be easy to cut the rubber hose and steal my gas - I was also thinking a steel hard line would work, but I'd have to find another fitting first
transfer pump (universal, for a carb'd car) - I used 1/4 riv-nuts to attach it to the frame rail (still need to put a fuel filter inline to pretect the pump)
a bit of protection to keep the hoses from chaffing against the frame rail, it also keeps them tied together nicely so they don't move around much
a few months ago I had to repair the main tank fuel pump bracket because the metal line on the outside finally rusted through, while I was at it I added an extra line to dump the fuel from the aux tank into the main tank, I had actually extended that fitting down to the bottom of the tank in the hopes that it would work like a siphon once fuel starts flowing (in case the pump fails/doesn't work out I could still use the aux tank w/ pump removed)
I tossed my spare tire back under there and noticed that the tank didn't affect my departure angle at all, though if I drop off an obstacle the spare will definately take the drop. If I know I'm hitting any rough trails I'll just take the spare off and toss it in the back. I am planning on making some kind of spare carrier for the rear bumper - I always liked the idea of being able to carry 2 spare tires for longer trips.
rear view
I still have to wire it up, but that'll have to wait for another day . . . the wife started giving me the hairy eyeball for working on the truck most of the day.
I definitely think you are having a better weekend than me now..lets trade :D
Turns out I was right, there was a leak in the galley, just not as simple as i'd thought, the bypass tube's fine..
:p:doh:
Looks good. I have the same tank, and had similar complaints. I ended up doing a factory in tank pump.
The details I'd change: I'd run a metal line above the fuel level, so if the rubber starts to deteriorate, it won't leak the entire tank out. Also, those pumps don't like to pull fuel, only push. Its a good idea to try and mount them below the fuel level, to allow gravity to push the fuel to the pump. Also be careful running it dry. Some pumps don't like it.
:p:doh:
Dude, I thought that was a decently fresh rebuild? Those intake ports look scuzzy. You know the oil goes in the fill cap not the throttle body, right? :D
I'm thinking I'd like to run a metal line off the tank, but mainly as a "fuel theft" deterent (I have all the fuel clamps turned in and hard to get to, but the rubber can still be cut). The hose I have on it now is EFI Fuel line with a blue liner (?) in it so I'm not too worried about the rubber breaking down anytime in the near future. What did you use coming off of your tank (fitting, line, etc)? Are you saying you were able to get a submersible pump into the NWMP tank (I'd assume you cut it open for that)?
I checked the paperwork that came with this pump - it said it can pull 20" of head (:rolleyes:) but I mounted it as low as I could while keeping it shielded from stuff that might get kicked up by the tires anyway. In my experience these pumps aren't very good - I went through 3 of them for my RV gen set (parts warranty) a few years back when I moved west. That was the old style though, with a metal case, we'll see how the plastic molded one lasts.
About the same thing I was asking when trying to figure out why my #1 injector plug was glued down so badly it had to be broken off so I can repin a new plug. Those intake tubes look about normal for a truck with over 100,000 on it, partially why I hate the factory setup of a pcv going back into the intake tract unfiltered. I had an inline filter when I had my S-10 buggy'd out to keep things clean, I might do something similar, basically a smaller setup to trap the particulate matter but let the fumes past so it'll still be CA SMOG legal. FWIW I had the top end only partially done less than a year ago, less than 13,000 miles and they're denying liability, because in their eyes I swapped to a 5 speed and 4wd and it's a part of the mechanical system and I've off-roaded it.
BTW, ;) Got a protractor handy, take a full shot so i can get both wheels as the base b/c I'd like to see if it's around 40 or so. :D
What is your final opinion of the NWMP aux fuel tank? Worth the trouble?
Reason I ask . . . . last summer I removed a similar tank from my '85 4x4. It came with the truck from the dealer. The tank was black plastic. It had reached the end of its life. Fittings had leaked for years. I also went through three fuel pumps, till it was found out that the main tank was filled with little black plastic shavings. Obvious that they came from the plastic tank.
Issue . . . . I miss the extended range that I used to enjoy. I am very interested in the NWMP tank. You opinion would be useful.
One more question. From your photos, it looks like there is an access panel from the bed of the truck to the fuel pump. Is that what I am seeing? Anyone know if there is a similar panel on an '85? I have had carpet in mine since forever, and I never even though of looking for an access to the fuel pump.
Check you states emission laws first, most are going to the "..not allowed on emission controlled.." laws. Yes, all 4Runners have that access panel, and yes, you always want to re-caulk (FIPG) it back down to keep those lovely fuel fumes at bay.
Corax, I'm sure you might have an alternative suggestion for secondary tanks for us in the "No-Zone"?
That's about as straight on from the side as you can get, so measure away (I was actually looking for one for 5 min to do the same thing)
I'm in NM, so probably no emissions issues, but I will certainly check.Since mine is an '85 PU, looks like I am out of luck WRT the access panel.
I'm not positive, but I thought my '88 p/u standard cab had an access panel behind the passenger seat . . . as far as an extended range tank goes, if you don't mind cutting out the "spare tire crossmember" you can go with a Ford E-series van tank in that location (I think early 90's, not sure on the years though). That's a fairly flat tank with ~18 gallons capacity and an internal pump and sending unit already in it. If you're interested I'd suggest searching around the forums a bit.
The NWMP tank is good, but pricey. I found mine on Ebay and had to rehab the rust on it - it is fairly thick gauge steel though, so surface rust should not be an issue
