ARCHIVE NPA: Rigid Industries IGNITE - Smallest Forward Projecting Light w/ GoPro Mount!
MRT Motorsports
MRTMotorsports.net
Las Vegas
Website
www.mrtmotorsports.net
NEW FROM RIGID INDUSTRIES!!
The Rigid Ignite™ is the smallest, most versatile light in Rigid Industries’ product line! Measuring approximately 1.4” x 1.4” x 2”, this flexible light packs 1000 raw lumens using Spot, Flood or Diffused beam patterns; perfect for any application where short range light output is needed. The Ignite also utilizes a Go-Pro® style mounting bracket which mates with an array of off the shelf Go-Pro mounts. Due to the wide range of mounting options, the Ignite’s applications are almost limitless. The compact and lightweight housing makes the Ignite a great choice for auxiliary lighting on cars and trucks, motorcycles, UTVs, and even marine applications. Low current draw (less than 1 amp) and voltage requirements (6-28 volts) makes the Ignite adaptable to any application. Single light kits include one Ignite, mounting brackets, and related hardware. GoPro Mount Not Included. Get yours from MRTMotorsports!
Watts: 12
LED's: 1
Raw Lumens: 1000
Lux @ 10m: 139
Beam Distance: 236 m
Peak Beam Intensity: 13939 cd
