SOLD Northern VA: 2005 LX470
Year
2005
  1. LX470
Oakton, Virginia United States
Mileage
166500
Color
rgb(30, 0, 255)
Outside Link
https://www.ebay.com/itm/144624961840
Posting my 2005 LX470
Price:$22,500
Miles:166k
Clean Carfax/Clean Title
Miami & SC owned until 2020
Partial dealer service records from new & full list of maintenance from last 4 years
Color: Blue Vapor Metallic
Interior: Gray, recovered/foamed front seats
In the last 1,000 miles: Oil changed, Tires Rotated, New Battery, New Wheel Bearings, New UCA/LCA, New Hubs, New Brake Pads/Rotors/Brake Line
Mods: TJM Front Bumper, ASFIR Front Skid, Stubby Antenna, 4x Rigid LED Pods, KC Hi-Lites
Pros: Fully up-to-date on maintenance, frame is exceptionally clean and uncoated, nothing to hide. Interior is exceptionally clean.
Cons: Hood/Roof Clearcoat faded, roof slightly worse. The clear coat under rear pop-outs and rear door windows is peeling under weather stripping. There's various rock chips, scratches and dings throughout, inline with a vehicle this age. Overall still cleans up exceptionally well, just wanted to be transparent about not expecting perfect paint.
Please see detailed recent maintenance below.
Purchased from original owner in Miami FL on 1/17/18 with 128,479 miles.
1/26/18 – 129,153 miles
Oil Change & Tire Rotation
2/16/18 ($1817) – 129,275 miles
Replaced Power Steering Rack
Replaced Coolant T-connectors
Replaced Both Front Axles & Seals
6/19/18 – 131,261 miles
Curtain Airbag Recall Performed
8/14/19 ($381) – 131,946 miles
Transmission & Transfer Case Fluids Replaced
Front & Rear Differential Fluids Replaced
3/12/19 – 135,179 miles
11/22/19 ($1815) – 138,825 miles
Replaced Spark Plugs
Replaced Timing Belt, Water Pump, Drive Belt & Tensioner and Radiator
Purchased from second owner in Charleston SC on 6/6/2020 with 141k miles
6/10/2020 - 141,040 miles
Oil Change
7/17/2020 ($884) - 142,873 miles
Replaced Front Driver and Passenger Brake Calipers & Pads
Full Brake Fluid Flush
8/15/2020 — 144,801
Oil Change
10/9/2020 — 147,200
Oil Change
11/16/2020 — 150,120
Front driver & passenger leather seat covers replaced & foam topped
11/24/2020 — 150,455
Valve cover gasket replaced
Rear hatch struts replaced
Power antenna mast replaced with antenna source lc conversion stubby, motor disconnected
Oil Change
Lower radiator hose replaced, coolant system topped off and burped
Rigid Industries LED ditch lights installed
2/11/2021 — 153,500
Bank 2 o2 sensor replaced
Oil Change
6/15/2021 — 157,790
Oil Changed
AHC Fluid flushed/refilled
Tires Rotated
Cleared Sunroof drains
6/29/2021 — 158,126
A/C system flushed prior to new compressor
A/C compressor w/ clutch replaced, refill/charged system
9/24/2021 — 160,028
Oil Change
12/30/2021— 165,010
Oil Change
3/10/2022 — 165,050
Replaced front Tie Rods
Replaced Upper Control Arms/Ball Joints
Replaced Lower Control Arms/Ball Joints
Replaced front Hub Assembly/Wheel Bearings
Replaced front Rotors/Pads
Replaced front Brake Lines
What wheels are on this rig? Looks great
Thanks! Going to miss it certainly.
Level 8 MK6's are the wheels...the center bore needs to be milled out a bit to clear the hubs, otherwise great/cheap wheel for these.
