NO power!!
Fairview, NC 28730
NO power!! Please help.
Tonight on my way home I tried to pass some deuche bag and floored it. I mean I got on the gas as hard as I could shifting before 3000rpm. Suddenly the rpms drop and I slow down. I get out of the gas and get back in the right lane.
I pulled into a parking lot and revved the engine. It idles smoothly and revs great and smooth but when I let the clutch out I can't give it enough gas to get it to move forward, without it trying to stall out. I push the clutch in and it revs back up.. I let the cluth out and give it alot of gas(more than normal) it all but dies. When I let the clutch out and push the gas a normal amount it will stall. So I have to floor the gas to keep it fropm dieing. The truck surges and jerks violently. What have I done.
What would cause this?
Fuel pump???
Sock filter on the fuel pump. Classic symptom on FJ62's.
Dunbar
Since your sig line says 60 series, bound to be the fuel pump or filter.
has the fuel tank been replaced under recall......... and when ?
Sounds like you have some crap in the carb. Sitting (no fuel flow) and it comes unblocked. Running and it gets restricted. Your not using much gas when you rev it up w/no load. This opinion is assuming the rest of the fuel sys is unrestricted.
