No Loss Valve Caps - Lowest price on the planet ☺
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
1914094
Imagine never losing a valve cap again while airing up or down on your off-roading adventures. No Loss caps are made by Extreme Outback Products and built for NATO military vehicles. Seems they want a valve cap that can hold tire pressures even if the valve core fails. Yes without a core. The No Loss cap is all brass with a knurled outer surface. Brass will not stick to your brass valve stem threads like those cheap aluminum caps. Road salts, road chemicals and moisture can set up electrolysis and actually fuse the aluminum caps to the brass valve stem threads. Inside the No Loss cap is a quality 0-ring for a positive air tight seal. Guaranteed not to leak even if the valve core is missing. Great for off-roaders that are airing up and airing down tires. The retaining strap keeps the No Loss cap attached to your valve stem. No more losing caps, storing them in your mouth (yuck!) or fumbling in cold weather with gloves on. Forget to screw your No Loss caps back on? Our retaining strap is strong enough to withstand 80 mph speeds with the No Loss cap just hanging there!! Can be used on any valve stem. The list is endless. 4WD's, RV's, sports cars, motorcycles, ATV's, Semi Trucks, construction equipment, farm equipment, planes, mountain bikes, go karts, drag cars, etc. Made in Great Britain.
IMPORTANT NOTE:
No Loss Caps can only be used on brass valve stems. Do not use on aluminum valve stems such as those equipped with TPMS.
We offer No Loss Valve caps for TPMS
Lowest price on the planet @ $14.50 with
FREE SHIPPING anywhere in the USA
Click here to purchase ► No Loss Tire Valve Caps - Land Cruiser Products - LCP
1914100
Will these be on the site soon?
Just Ordered! Thanks Phil, I stopped caps using these bc I was losing them monthly.....
thanks for solving the issue for those of us who cant seem to keep track of caps
Are these still available?
