After the winter I seem to have lost my A/C. The compressor doesn't come on when turning on the A/C, just free-wheeling. I tested the resistance of the compressor and it shows 800 Ohms which is within spec. I also checked to make sure the clutch plate kicks in by providing 12v directly to the compressor. It did kick in when doing this, but I didn't dare to do this for very long in case I'm out of refrigerant which I believe would cease the compressor. During the short period of having the compressor working I checked the "window" but saw no bubbles. I guess this means the lines are either full or empty of refrigerant.
Does anybody have access to the FSM and can tell me what the resistance should be on the pressure switch if I test it? The switch is located in the same spot as the "peep hole".
I'm thinking that I have a leak and that the system is empty which would make the system not work, but I would like to test everything else first before I take it to the shop. I'm currently on the road so I have some time before I get back to town for some further testing.
Any other ideas?
Any other ideas?
