- Year
- 2018
- Vehicle Model
- 4Runner
- Mileage
- 63000
- Color
- Gray
$45K and price is firm. Located in northern New Jersey. Text me at 646-833-8858 if you are serious.
63K miles, clean title in hand, no accident, no damage, carfax report available upoon request, no frame rust. The build material cost alone was over $29K. Fully built overlanding rig that is ready to go around the world as it sits, no expense spared with this build. Based on a 2018 Toyota 4runner Off-road, lived its first 2 years as a regular 4R and mod at 35K miles. If you read through the build list you know this is a first class build. I bought it from North Carolina last year, covered garage all its life, no frame rust. Oil changed, all 4 brake pads and 2 rear rotors changed 200 miles ago. I get 16.6mpg and I live in a populated area.
This was built to be an overlanding vehicle (as you can tell from the tire size...), never did any serious off-roading. I enjoy fire roads and camping more. You get everything in the picture, a few items are not in the picture so here is the list:
• 4 ActionTrax (used 2 of them once)
• 2 Pelican cases (pre-drilled to bolt on the roof rack)
• Roam awning
• Custom built rear seat deck (you can remove rear seats and use this for mam storage)
The build list:
Engine/Drivetrain/Suspension
● Dobinsons Snorkel
● OE Metal oil filter housing
● ECGS Clamshell Bushing
● ARB Rear Diff/Locker breather - Located by fuel filler
● Dobinsons differential drop
● Dobinsons 574 Extended Travel Front Struts
● Dobinsons 314 Front Springs
● Dobinsons 701 Rear Shocks
● Dobinsons 329 Rear Springs
● JBA Upper Control Arms
● Toytec Front Swaybar Spacer
● OE 3rd Gen 4Runner rear sway bar end links
Wheels/Tires
● 17x8 Level8 MK6 Wheels - ET0 - Gunmetal (x5)
● Falken Wildpeak A/T3W - 255/80/17 (x5) – 80% treads left
Armor
● Mobtown Offroad Aluminum Front, Transmission, & Transfer Case Skid Set
● LFD Off Road Steel Gas Tank Skid
● C4 Fab Steel Rear Differential Skid
● RCI Offroad Steel Rear Link Skids
● SDHQ ABS Sensor Guards
● Mobtown Offroad Bolt-On Straight Sliders
● Warn Slimline Front Bumper w/ Smittybilt X2O 12,000lb Winch (Synthetic Line/ Factor55 Flatlink)
● LFD Off Road Dual Swing Rear Bumper
○ Drivers Side Straight Spare Tire Mount
○ Drivers Side C4 Fab Camera Relocation Mount
○ Passengers Side Hi-Lift Mount
○ Passengers Side CBI Off Road Dual Jerry Can Mount
○ Passengers Side weBoost OTR Antenna
○ DS/PS Ground Lights
● LFD Off-Road Full-Length Steel roof rack with straight fairing
● Ram mount for go-pro/camera on roof rack
Lighting
● 2022 Toyota 4Runner OEM LED headlights
● Auxlight LED Turn Signals
● 2022 Toyota 4Runner OEM LED fog lights with Lamin-X Yellow Film, independently wired to 4200 Mini controller
● 2 30” SuperBright LED Slim Series grill lights on Cali brackets
● SuperBright LED 50w Quad Side Shooter ditch lights on Cali brackets
● SuperBright LED Slim Series 7” side lights (2 per side)
● Rear Lights (Roof) - Auxbeam LED Side Shooter
● Rear Lights (Bumper) - Nilight Flush Mount LED (Rear lights triggered by reverse circuit and/or by 4200 Mini Controller)
● Taillights - Diode Dynamics Tail-As-Turn Module
● Reverse Lights - JDM ASTAR 921 & 7440 LED
● Maxxima Ultra-Thin Low Profile STT LED in rear bumper swing outs
● Rear Aux Brake Lights - Mictuning 16” LED Trailer Light Bars (x2)
● Dust Light Controller - Whelen UHF2150A Headlight flasher
● Ground Lights - Profile Peak Magnetic Rock Lights White (x11)
● All Interior lights LED - Auxito/Sirius
● Cargo Lights (White) - SuperBrightLEDs Strip Tape Light (x2) & KC Cyclone Diffused
White LED (x2)
● Cargo Lights (Amber) - KC Cyclone Amber (x2)
● Under Hood Lights - Profile Peak Magnetic Rock Lights White (x2)
Interior
● Customized leather seats (thicker and more durable than OEM)
● Expedition Essentials T4RPAM Dash Mount w/ Dual USB Charger
● Dash Ram mount for large cellphone
● Dash Ram mount for Go-pro
● Feniex 4200 Mini Light Controller (one front, one rear)
● Llumar/Formula One Window Film - Air Blue 80 (Windshield) & Pinnacle 15 (All other
windows)
● Rostra Toyota Specific Heated Seats – Front
● Solex Center Console & Glovebox Organizers
● Steel center consle Safe
● Rexing V1 4K Dash Camera
● Orange Boxx Rear Window MOLLE Panel Set
● Fire extinguisher and holder on the MOLLE Panel
● Fabric MOLLE Panel on the back of driver seat
● Rear Storage Box accommodates 4 x Front Runner Wolf Packs (80/20 1” Quick-Frame, PVC Side/Rear Panels, 1/8” Aluminum)
● ARB 50Qt Fridge/Freezer with insulation blanket
● DFG ARB 50Qt Fridge Slide
● Anytime 400w Mod for Inverter
● Switches (Dust Light/Cell Booster) + dual voltmeter in center console
● Anytime backup camera switch in dash
● Sound Deadening
○ 50-80% coverage on inner/outer doors, rear quarter panels, hatch, B/C/D pillars
and floor with butyl (Noico/Siless 80mil)
○ Noico 150mil Closed Cell Foam on inner doors, rear quarter panels, hatch, and
Floor
○ Noico 315mil Closed Cell Foam on floor of cargo area
○ 1/2lb (1/16”) Mass Loaded Vinyl on floor ($100)
Stereo
● Pioneer DMH-WT7600NEX headunit Wireless Apple CarPlay and Andriod Auto
○ Parking brake bypass module in addition to software override
○ SXV300 Sirius Tuner w/ external antenna)
○ iDatalink Maestro RR w/ OBD Integration)
○ iDatalink SAT-TO2 for OEM GPS Antenna integration
○ Metra Gloss Black dash kit
○ USB/HDMI Input in place of OEM USB/Aux
○ Front camera input run to under PS dash
● Kicker KEY200.4 Amplifier
● Kicker OE-Fit Subaru Dash Speakers
● Hertz X 170 Front Door Speakers
● Hertz X 130 Rear Door Speakers
● Rockford Fosgate R1 Rear Hatch Speakers
● Alpine PWE-S8 Powered Subwoofer under Driver’s Seat
● Stinger 4000 Series RCAs
● Conext Link Speed Wire)
Electrical
● ArcLight Adjustable Voltage Booster
● Champion AGM Group 24F Main Battery
● Northstar AGM Group 27F Aux. Battery
○ C4 Fab battery tray
○ 120V socket to charge Aux. Battery while camping
● C4 Fab Aux. electrical panel
● Battery Doctor 150A Battery Isolator
● Victron Smart IP65 15A AC Charger - Bluetooth enabled
○ NOCO Plug in Bumper
● Pre-Wired for portable solar charger under hood
● 12 Outlet & 6 Outlet Blue Sea ST Blade fuse blocks under hood
● 6 Outlet switched power Blue Sea ST Blade fuse block under dash
● 12 Outlet Blue Sea ST Blade Fuse Block in cargo area
● 4 Outlet Blue Sea ST Blade Fuse Block under rear seat
● SAE Plug on Drivers Side rear cargo area for fridge
● DT Connector behind Drivers Side Tail Light panel for removable connection
● Dual 2.1A USB Drivers Side Cargo Area
● 12v Drivers Side Cargo Area
● QC3.0 USB + Voltmeter Passengers Side Cargo Area
Communications
● weBoost 4G-X Cell booster w/ OTR Antenna on Rear Swing Arm, interior antenna on
T4RPAM
● Tram Hood Lip NMO Mount (x2)
○ RG-58 Coax w/ PL-259 Connectors, Under Center Console / Pass. seat
• Roam awning
The build list:
● Dobinsons Snorkel
Wheels/Tires
Armor
Lighting
White LED (x2)
Interior
windows)
● Sound Deadening
Floor
Stereo
Electrical
Communications
T4RPAM
